Hi, great forum here.
Im building a low level deck, with limited clearance in Eastern Melb. Nice clay soil with lots of rocks!
I'm down to 500mm deep x 450 x 450 wide.
I will only have 150mm clearance between the underside of the bearer and the ground, so I'm curious about what stumps I could use?
I don't like the idea of concrete stumps, and am considering having the bearers sit directly in a pryda type stirrup, but cant find anywhere that says this is an accepted construction method? If this is ok, does the entire stem need to be encased in concrete?
The other option is TP H4 posts ontop of a 200mm thick bed of concrete, but obviously the concern is the post rotting out.
Bearer span is 1500 and joist span is also 1500 @450 centes so going to use 2/90x45 h3 for bearers and 90 x 45 joists.
Community manager's note: Check out How to build a low-level deck for expert advice.
