Brick wall house constructed in the 90s. It now has plasterboard in front of the bricks - which I am guessing is a dot and dab wall so about 5 - 10mm void between the plasterboard and the bricks.
On to this plasterboard (then anchored in the bricks), I need to screw in an MDF (which will then have a pinboard on it - with the intention of hanging a professional ( > ~5 kilos) dart board) board. Question is what can I use to anchor the yellow tongue 1000mm x 500mm on to this plasterboard?
Google suggests using Corefix Dot & Dab Wall Fixings. YT videos make this option look promising. Essentially has a plug that can be hammered into a drilled hole. Then a metal sleeve is slid in - then a bolt. I find no equivalent in Australia, at least on google. I can't just use Anchor RamPlug kind a thing because as I screw in - the plaster board will bow/bend in. Feels like I am surely searching incorrectly - I have read https://www.workshop.bunnings.com.au/t5/How-To/How-to-hang-just-about-anything/ba-p/87672 - but it doesn't contain anything for my situation.
