Any recommendations for preparing a gloss painted walls and wallpaper adhesive surface for cornice adhesion?
I have most of a bag of CSR cornice cement and was planning on using this. But, the walls are either old gloss painted or have wallpaper adhesive/primer (wallpaper is removed and the house is from the 60’s), so I am thinking I will need some sort of primer to get better adhesion of the cornice cement to the wall - particularly as I have plastercast cornice 145x115mm. I have done a quick sand at 60grit but most of it still feels pretty smooth.
I saw a video of someone using spray adhesive Trim-Tex along the section that the cornice bead will be, to make it a rough surface once dry. Are there any other options? (I can’t find a local store that stocks trim-Tex in Perth)
