Hello
I want to install a water tank next to my bush block shed. It's for garden water, not potable water.
The problem is this. The open space, where there was a tank previously but long gone, and where I would like to install the replacement tank is about 1850mm from the edge of the shed to a open drainage trench. The tank I'd like to install is 5000l / 1830mm dia - a tad larger than the old tank.
I intend to construct a base from treated sleepers, @75mm thick. After I take into account the "apron" of 175mm from the edge of the tank to the near edge of the sleeper (manufacturer advises 150mm min) and the thickness of the sleeper (75mm) I will need a min of 1830mm (tank) + apron and sleeper (2x 250) = 2330mm. The diagram below might help understanding my word salad.
This scheme runs well into the drainage trench.
My question is this: could I extend the box into the drainage trench, and back fill and compact the soil before filling the box with FCD? Or must I use undisturbed ground? I would excavate the far side of the trench to restore its width, so the trenach could keep functioning.
I would be grateful for any thoughts and advice.
