According the to standards
Structural plywood wall cladding must—
(i)
comply with AS/NZS 2269; and
(ii)
be fixed in accordance with the following:
(A)
Where structural plywood acts as combined cladding and structural bracing it must comply with Table 3.5.3.4.
(B)
Sheets not more than 9 mm thick must be fixed using 2.8 or 3.5×30 mm long galvanised clouts or flat head nails spaced at—
(aa)
150 mm centres along sheet edges; and
(bb)
300 mm for intermediate fixings.
(C)
Sheets more than 9 mm thick must be fixed with 2.8 or 3.5 mm galvanised clouts or flat head nails with a length calculated using the following formula:
Minimum nail length (L) = plywood thickness + (10 x diameter of nail)
(D)
The fixings must be located not less than 9 mm from the edge of the sheet.
What screws would be recommended to use in places of the 2.8 or 3.5 mm galvanised clouts or flat head nails
Thanks
