Hi team,
I am planning to laying lawn seeds on my front side of house nature strip. Last night I cleaned the place . Is it need top soil? Which lawn seeds best ? Location Victoria Melbourne.
thank you
Revi
Hi @Revi,
For a nature strip in Melbourne, preparing the area well will give your lawn the best chance to establish. Adding a layer of topsoil isn’t strictly essential, but it can really help, especially if your existing soil is poor, compacted, or sandy. A 2–3 cm layer of quality topsoil will improve moisture retention and give the seeds a better medium to germinate in.
Couch and kikuyu are your main options. Couch grass is a good all-rounder for sunny areas, it’s hardy, establishes fairly quickly, and tolerates some drought once grown. Kikuyu is very vigorous, spreads fast, and is great for high-traffic areas, but it can become quite thick and may require more regular mowing.
Both prefer full sun, so if your nature strip is shaded, they may struggle. For establishing either, it’s still worth lightly preparing the soil, and adding a thin layer of topsoil can help the seeds take root more easily. Keep the area watered consistently until the grass is well established.
After sowing, lightly rake the seeds into the soil, keep the area consistently moist until the grass establishes, and avoid heavy foot traffic for the first few weeks.
Here's a helpful step-by-step guide: How to grow grass from lawn seed.
Thank you for reply
area is 12 Mtr by 2.60 mtr .
how many kilograms seeds needed.
Coverage rates are relative to the specific product used, but you should be fine with 1kg of most lawn seed varieties.
For example, this Scotts Lawn Builder 1.4kg Seed & Feed Couch Lawn Seed will cover 100 square metres when sowing a new lawn, and this Scotts Lawn Builder 1.4kg Seed & Feed Kikuyu Lawn Seed will cover 60 square metres when sowing a new lawn.
Whatever seed you purchase will have a coverage rate on the packaging, so just double-check the coverage rate prior to purchase to ensure that it will cover the 31.2 square metres of your lawn.
Thank you Jacob,
could you please advise me which nail gun good for wall decorative moulding installation. Nail gun . I am attaching moulding images . Which glue best . Need install on top of gypsum wall .
Hello @Revi
If you really want to use a nail gun I suggest at looking at a brad nailer such as the Ryobi 18V ONE+ 18GA Brad Nailer as an example. Generally speaking, you could use a standard hammer and nail to hold the timber moulding in place. In regards to the adhesive, I suggest using Selleys 320g Liquid Nails Construction Adhesive to attach the timber moulding to the wall. It's versatile and works on a variety of surfaces.
Hi ,
thanks for response
I have completed installation of “white pre primed VJ panel” indoor my wall . I am thinking to do black paint on top of that like mat finish. I don’t prefer shiny. area 275 cm by 175 cm
and second floor all 370 cm by 130 cm
how many litter paint need ?
is Matt finish good to indoor ?
is pre primer need again?
my wife all pictures uploaded please check
A one litre can of primer will conservatively cover 14sqm depending on the thickness of the coating and the material being painted. A top coating will cover 16sqm, but because you are doing two coats for the top coat, it will be 8sqm for two coats. If the wall is 2.75 x 1.75 its area is 4.81 and if the other room is 3.7 x 1.3 the area is also 4.81. You will therefore need 1 litre of primer (one coat each wall) and 2 litres of top coat to paint your walls.
In regards to the paint finish, I suggest using low sheen instead of a matt finish as it tends to gather more dust quickly.
