how do I get this off tge vertical blind so I can replace to turning mechanism
Hi @tina4,
Is there anything on the opposite end of the blind bracket? Any screws or obvious screw caps?
If you can't find a screw or screw cap anywhere, then I suspect you will have to pop something off to pull out the mechanism, possibly the black plastic around that inner aluminium rod.
If you use a flat tool like a flathead screw driver or a butter knife to gently lever the black plastic piece away from the aluminium, does it feel like it moves at all?
Give this a try and let me know how you go.
