Dear Bunnings Community,
I would like to find a way to redirect the current AC split system drain hose away from the outer brickwall. The water is currently dripping onto the gap between house and concrete path (currently filled with foam). Can I use a L-shape pipe of some sort attached to the end point of the hose to direct the condensation water away from the house? There's a concrete path around the brickwall with drainage to the SW system.
Please refer to the attached photo for reference. Thank you in advance for all your suggestions!
AC drain hose needs redirecting
