Does anybody know if these are able to be removed at all? And if yes how do you do it? Thank you 🙏🏼
Hi @megsp,
Taking an educated guess, I'd say that those domed pieces are caps that conceal a nut or a screw that can be removed. The only other thing I could think is a possibility is that they are a cap nail.
Try slipping a flat tool like a chisel underneath the bottom edge of them and levering them up. If it is a cap, then it should pop off and you can remove the fixing beneath with a socket set or screwdriver. If it is a cap nail, then you would just need to lever it out in the same way.
Give this a try and let me know how you go. I am happy to assist further if required.
Thanks Javob
I’ll try that and keep you posted.
