First time building a shed. Tested with water and notice water leaking down between roof sheets and the roof trims. Is this normal?
What suggestions to fix this or make the water flow maybe to the ends?
Also found another water issue. The water flows down the door jamb where the bottom end sits inside of the shed. Not sure why its designed like that but im sure I have installed it correctly. What should i do to fix? Just pack it up with silicone?
Also had third problem which not sure have any one experienced. Which I have researched and know a fix for. Thought I shall share incase other people in same boat.
Water can also overflow in the U cannels at the bottom of shed so you need to also pack it with roof gutter silicone. Can be done internally and externally or both.https://youtube.com/shorts/ReTmQe82qDw?si=jLvRTvG9BdkM2chr
Let me know your suggestions guys. Thanks
