what do you recommend for the easiest way to clean an air vent. Or is it easier to remove and replace them. If so, do you supply in store.
Thanks
Welcome to the Bunnings Workshop community @Bacon Big Boy. It's terrific to have you join us and many thanks for your question on vents.
Could you let us know whether you are referring to the internal ceiling vents or the external vents on the unit, and how dirty or discoloured they are? If you can upload a couple of photos, our members can give you much more specific advice about cleaning or replacing them. If these are the internal plastic ceiling outlets, they can usually be cleaned with warm soapy water, but if they have yellowed or become badly discoloured over time, the easiest option is often to clean them thoroughly and then spray‑paint them white with a plastic‑safe paint rather than replacing them. Images will help confirm the type of vents you have and whether removal or refurbishment is the better approach.
Let me know if you need a hand uploading images.
