Hi all,
I currently have cornice in a room that will be replaced with a square edge, and I have some questions about the process.
Being a 1970s home, the wall and the ceiling gyprock has quite a large gap from the Junction. I plan to cut out gyprock strips and insert them right up onto the ceiling joist from the wall to bridge that gap.
If the gap in the ceiling is large, I will do the same with the thicker ceiling gyprock as well.
I plan to use a wide, hybrid corner tape.
However, I wanted to ask this forum if I should be utilising an angle bracket, and if so, how? I could put an angle on the EXTERIOR of the corner. I could also use a pvc internal corner bracket instead of tape. I note intex has a angle/tape product, but it isn't listed in bunnings special order despite carrying the brand
I considered shadow line but I don't think the wall is straight enough and my plaster skills aren't quite there.
Thanks!
