Hi everyone,
As a resident in a unit block with a shared garden – I’m seeking advice on drainage issues regarding a sloped garden area and a concrete bin shed. We have a paved sloped path up the side of the house, which levels to a flat paved area that sits above the garden bed. Anytime it rains, rainwater absolutely decimates the slope and carries all the soil and water to the bottom of the hill to the base of the shed, and has raised the soil level which washes soil into the shed floor. Located Northern Sydney on the coast, so the rain and wind can get brutal sometimes. This erosion has also completely claimed the brick edging that once lined this bed.
Agapanthus at the top of the slope provides bare minimum stability. Camellia tree also provides some stability, but has proved a contributor to the soil levelling issues – garden was previously mulched, the mulch collected at/washed away to the base of the tree, and over time, has compacted into a very thick layer of what looks like mycelium. I’m fairly certain that the soil is just that, no clay or sand to worry about.
Due to major issues with Anredera cordifolia necessitating arduous manual tuber removal, I was already planning to essentially excavate the area where the soil level is higher at the base of the shed. Truthfully, I believe that there is probably access to a storm drain, however I'm working under the assumption of no access because strata have made it clear that they would prefer not to shell out for a plumber, so this probably rules out a French drain or something similar. Leading to the shed is a pebble path, and the other side backs onto a retaining/property boundary wall, so the practicality of digging a trench and redirecting with berms etc. would be null, since I think the water would then just seep under the shed gate. Would a soakwell be a recommended solution in this instance?
Regarding the slope, of course soil leveling and planting of natives to reduce erosion is a high priority – this issue may be addressed/rectified when property is assessed by a landscaper, but in the meantime, I was also wondering how to best reclaim the edging? It has been overrun by a thick root system, which I have begun to remove already, however I’m not sure of the best way to dig out and level the soil surrounding the edging…perhaps this is best left to the potential landscaper?
I’m in my early 20s and have done lots of bush and wetland regen, but since my strata doesn’t take the suggestions of young people too seriously, I’m looking to provide as much of a concrete solution as possible to spur them into action. Any advice will be sincerely appreciated.
Thanks again in advance,
Neo 😊
