I have a Hardie Secura Flooring Sheet that I plan to use as a benchtop for an old brick barbecue. There is currently a timber benchtop which has failed even with 6 monthly oiling. It is exposed to the elements so I plan to seal the flooring sheet and then tile with 600 x 300 porcelain tiles.
What should I use to seal the Hardie Secura Flooring Sheet?
Is there anything else I need to consider?
https://www.bunnings.com.au/james-hardie-2700-x-600-x-19mm-hardie-secura-flooring-sheet_p0851522
