Hi!
To save some $ we are exploring if we can do the tiling on a new outdoor concrete slab in metro Brisbane.
The slab will be new, but by the time of tiling will have cured for at least 30 days. The size of the slab is 7.25m wide x 5m long and it will be a level surface to allow posts and building a roofed deck above it. The 5m length is what needs to fall away from the house.
Our builder has advised that if we are going to tile, it needs to have a slope away from the house to allow water drainage. I need to double check this, but I think we need a fall of 1:100 per metre (10mm per m) which gives a 50mm drop from the house to the end of the patio.
How do you do this to ensure a smooth gradual slope with no dips in the middle over such a big area? eg do we pour it in sections?
Do we need to screw in some wooden supports to the sides to hold in the cement (and potentially form a guide for the slope)?
What type of concrete should we use (given we are amateurs and won't be moving as quickly as a pro)?
I've read another discussion (https://www.workshop.bunnings.com.au/discussion/246438) which has some helpful tips about first creating a slurry and using bondcrete.
Also, given that it's going to still be quite a new slab, I've read some how-to's about something called an uncoupling membrane to mitigate against tiles cracking as the slab continues to settle. Is this needed in the Brisbane climate since the slab isn't really going to be exposed to much temperature variation? It may also just be a North American product as I haven't been able to find it here, or it's called something else.
Let me know and thanks in advance for advice!
