Wondering if anyone has cheapish suggestions to fix this crack in the shower base. Noticed it about a year ago and stopped using it, but was hoping to fix it. Can't say with certainly what it is made from. Any suggestions would be great. Thank you
Hi @Ausgill,
It’s likely that your shower base is made from acrylic or fibreglass. Unfortunately, I’m not aware of any products that can reliably repair a crack in these materials. A proper fix would generally require replacing the tray. If your budget allows, it’s also worth considering replacing the shower screen at the same time, especially if there’s any corrosion or wear around it. Installing a shower tray correctly requires ensuring proper alignment, drainage, and sealing, so I would strongly recommend enlisting a professional for the job to avoid future leaks or damage.
