Hello, is there any chance I can order custom sizing for the below shelf in store? I need them to be 46x44cm.
https://www.bunnings.com.au/lugna-white-adjustable-cabinet-shelf-to-suit-450-x-580mm-2-pack_p0430943
Hello @Midnight456
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about getting a custom shelf.
I suggest speaking to the In-store kitchen specialist. They will be able to order custom sized Kaboodle panels for you that you can use as shelving. They will be able to accommodate your request for a 460mm x 440mm shelf panel.
Another option is to cut the panel yourself using CUSTOMpine 1800 x 445 x 16mm Carcass Shelving E1L White Standard Particleboard. You'll need a circular saw to cut the panel down to the size that you need. The exposed sections will need to be covered with Moroday 5m White Iron-on Melamine Edge in order to give it a nice uniform finish with no timber sides exposed.
