Hi Bunnings Team,
https://www.workshop.bunnings.com.au/discussion/comment/148805
I’m dealing with a similar issue as in the post above, but the gap ranges from under 10 mm to just over 40 mm, and it seems the concrete has already moved down.
In some sections the gap is around 30 mm wide and 120 mm deep, and I’m unsure what material is best to fill it.
Other areas are wider than 40 mm, and I can’t find Abelflex in that width, so I’m looking for an alternative filler.
I’m also unsure whether it’s acceptable to reuse the old Abelflex, as some sections are tightly wedged and extremely difficult to remove or push down. In case I can reuse it where I am not able to take out easily, what is the best way to create enough space for the sealant.
Current condition of Abelflex where I can take it out.
Thanks
