May have overtightened the tap of maybe the dome type tap valve just dont suit my sink. Issue is how do i remove the fallen rubber tap valve inside the tap hole? I used a philips screwdriver poke inside and felt the rubber still sitting there. I replaced the tap valve.woth a normal one and water supply uninterrupted.
There are so many
valves which tap valve is strongly recommended so i dont need to close too tight? I did use reseating tool to clean it before.
