Hello,
I’m undertaking a simple bathroom renovation which entails removing and installing a new bathroom vanity. The process seems simple enough but I had a question that may cause a problem. As shown in the pictures my taps are away from my drain pipe and as a result has some extra connections. These don’t seem to have a screw off point that I can see close to the wall of the cabinet. If i disconnect everything that I can see (with the water main turned off and pipes drained prior) will these just pop off or will there be something i can screw off behind the cabinet? I don’t want to potentially damage any pipes and if anyone had any advice it would be greatly appreciated before I start? I know that once I have everything down to simple wall connections that Ill be attaching a cap and thread before turning on the main water again. Thanks
