We recently installed a Sigenergy solar inverter/battery unit in our carport. It's not particularly loud, but it does sometimes make a bit of a humming noise, which can be a little annoying when outside. I think the noise is being amplified a little along the carport wall.
I'm trying to think of solutions that aren't too expensive to dampen the noise from the carport opening. I have the following requirements:
* The solution can't be too expensive (i.e. several hundred is ok but not in the thousands)
* We also need to walk through the carport space regularly, so the covering needs to either have a door, or something we can pull back easily.
* The solution needs to be something I can remove without a huge amount of effort if needed. We may need to free up the space in the future if we're doing further renovations in our backyard.
* Ideally, would be good to keep a bit of light coming through.
Please see the image attached to get an idea of the space I want to cover.
I've had a couple of ideas, and wanted to see if anyone has any other suggestions…
* Could buy reasonably thick clear tarp (like the clear tarp used for outdoor areas in restaurants), and could use Velcro strips on the side brick walls and roof to secure it. This would be easy to remove and partially open. My concern with this solution is it may not do all that much to dampen the noise (note, that noise it's that loud, so I'm hoping it would be enough)
* Could put up panels that are attached to the top wooden beam and have something on the ground to keep them in place. This would require one of the panels to open like a door (see image attached with rough design.
Please let me know what you think and if you have any other ideas.
