How would i go about fixing a flush system on our spare toilet and what parts would I need. Its the unit under the push button that is not there anymore
Hello @Mirum
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your toilet cistern.
Please note that any plumbing works must be carried out by a licensed plumber for safety and compliance.
The possible replacement units for your cistern are the FIX-A-LOO Cable Flush Cistern Outlet Valve, the Fluidmaster Dual Flush Toilet Cistern Valve And Button and the Kinetic 17 - 25mm Single Flush Outlet Valve. If you have not done any plumbing before, I suggest engaging the services of a plumber to replace the flushing mechanism of your toilet. Replacement will involve plenty of adjustments and modification of the cistern cover.
Another option is to replace the entire cistern with a new one such as the - Stylus Allegro Plastic Cistern it is an excellent compatible replacement.
