Can I please get some help with removing this double sided tape from the trim of my car.
Can you please suggest me a product which won’t impact the trim or glass.
Thank you
Hello @gaganprachi
Thank you for sharing your question about your car trim. I propose looking at using De-Solv-it 125ml Sticky Spot and Stain Remover its natural citrus base should be safe enough to use on the trim of your car. Before you begin, I suggest testing a small portion first to make sure that it is compatible with the trim of your car. If there are no adverse chemical reactions, you can then commit the entire trim.
I also suggest using a Trojan Safety Scraper With 5 Blades to remove the tape on your trim
Please remember to wear personal protection such as gloves and goggles when working on your project.
