I am trying to hang a bamboo blind. The instructions were to use 3 x cup hooks screwed horizontally into the window frame, and then weave the pre-attached circular rings over these hooks. However, I have found that there is not enough space between the cup hooks and the top of the window frame to allow me to manoeuvre the pre-attached rings so they are at the correct angle to hook over the top of the cup hook. When I try to do this, the wooden bar at the top of the curtains hits into the top of the window frame.
I am hoping for your help in coming up a solution - perhaps attaching a split ring to the pre-attached rings to give me a bit more space to manoeuvre although this may cause the blind attachment to be less secure. Alternatively, maybe I could swap the cup hook for an L hook so the rings could slide on more easily?
I can’t screw the cup hooks hanging vertically because the blind does not fit within the window frame dimensions so has to sit in front.
grateful for any suggestions!
