Hey,
Currently I have an existing retaining wall sitting about 100mm from the main boundary fence. This is due to the plinths breaking and the neighbour being much higher without a retaining wall.
Regardless, we are wanting to install the Ekodeck Batten Screen Castellated Panel along this section of the fence for the length of the retaining wall. I beleive we would need some sort of frame to support this.
I currently plan to use something like the Galvenised Steel Fence Bracket or Galintel Outdoors 6mm Steel Fence Bracket. these will both attach fine to my steel posts for the retaining wall. Ideally I would want to install a Steel Posts onto the bracket and then 3 steel rails roughly 600 apart.
Question is, can these posts be attatched to these brackets. And how would you attach rails between the posts? Ideally want the rails between the posts and not accross to keep in line with existing retaining wall.
