Hi folks, I want to unscrew and remove these taps and cap them. They are in the laundry for an old washing machine. Surely its either 15 or 20mm…id prefer not to remove them until I have the caps! The outlets are 25mm.
Thanks in advance guys.
Hi @jimbarry41,
Threaded wall outlets for washing machines are typically 15mm and suit 15mm caps. Occasionally, you might see 20mm in older homes or high-flow setups. Thread tape will also be needed to seal the cap.
Please be advised that this is considered plumbing work and requires a licensed plumber to perform it.
