I have recently got a battery installed at home on external brick wall under the eaves. The installer recommended me to have a shade for it because sun hits the wall between 10:30 to 1pm . Other times it’s all ok. The fence and wall are almost a meter apart.
There is only 350mm between the inverter and eaves. The vendor recommends at least 300mm clearance on all sides of inverter . I like to know what is the best shade I can install here.
Can I do something from the gutters or eaves to the fence; it’s only 800mm there. using a shade cloth as a sail or fixed awning would require them to be hooked to the wall where they’re will be a clearance issue.
thanks
