I have a colourbond fence atop of retaining wall. Posts are help by gal brackets on the H beams. Due to house pad level being 100 mm higher than planned, the top of concrete sleeper is about 100mm too low, meaning once I install a 100mm pathway the concrete or the garden bed will sit against the fence. I have seen under fence plinths that can be installed by removing fence panels and bottom rail and then reinstalling the fence panels. If I install a 200 mm under fence plinth my posts will be 200mm short. How do I extend the posts and don’t do any cutting of the panels.
do you supply under fence plinths?
