how do I remove decking oil stain that has stained the colour bond fence. I have tried turps. It’s in a trick spot
Hello @mishbish
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Colorbond fence stain.
Would you be able to let us know what decking oil product you used? We'll then be able to contact the manufacturer to determine if there might be a chemical stripper that can be used to remove the stain on your fence.
I have also tried degreaser doesn’t budge
Since it is a water-based product, I suggest using DIGGERS 1L Methylated Spirits and a clean rag. Please do not let any of the methylated spirits drip onto your deck as it will stain the finish. Make sure to keep changing to a clean section of the rag so that the stain does not spread further as you clean it.
