Hello All,
I am installing ekodeck castellated panel screening. I'm looking to install a steel frame to fix this too.
I'm now looking to use 50 x 50mm Gal Steel posts set into concrete roughy 1.8 - 2m high. I plan to run 38 x 25mm rails. I want these to run between each post, not across the face. (so not using a saddle bracket).
What is the best way to do this? I have come accros these brackets for pool fences ProtectorAl 38 x 25mm Black Aluminium Pool And Garden Fence Panel Brackets - 4 Pack which I'm unsure if these would be suitable given the use and weight. The other option could be reinforced brackets. Which look to be quite durable and heavy duty.
I'm sure i'm not the first to try do this, I expected there to be something similar to this - Double Lug Fence Bracket but for the smaller rail size.
Any suggestions or expert advise would be amazing!
