One of the eaves of my house has rotted. Can I get some advice on repairing it myself
it as I have not been able to find a tradesman who repairs eaves.
Hi @Zog,
From the photo, it looks like your eave has suffered significant water damage, and the mould growth on the exterior appears to have originated from inside the ceiling cavity. This suggests a substantial roof leak, and there’s a real risk that the roof structure itself could be affected. Given the extent of the damage, it’s strongly recommended to have a roofing or leak specialist inspect the issue first. You might also consider contacting your home insurer, as this could be covered under your policy.
It’s difficult to provide DIY repair guidance in this situation because you would first need to identify and repair the roof leak, then carefully inspect the cavity for timber rot, mould, and damaged insulation. Only after addressing these issues would you be able to safely re-sheet the eave. While it’s possible this is just surface growth, it’s likely that removing the eave sheet will reveal more extensive mould and dampness inside. Safety and long-term integrity should be the priority here.
Let me tag @Nailbag for his thoughts.
Thanks Mitchell.
Hi @Zog
As with @MitchellMc thought that this looks like severe mould due to the blackness typically caused by water ingress and/or extreme dampness in that area. First step if not already underway is getting the cause rectified before repair. I would get a leak detection service in to solve this and then they can advise the next course of action before dealing with the eve.
I've repaired a ton of mould effected eves with chemicals and specific paints. But this appears far more serious and would requirer full replacement. To neatly replace eve sheets and trims is in my opinion are reasonably advanced project both in fitment and working overhead which really complicates things but is doable. However, I would recommend that you more simply save money by removing the damaged trims and sheeting yourself. Then continue your search to find someone to replace them. A decent handyman/handyman service is going to be your best bet, then someone who specialises in small job carpentry.
Nailbag
Thanks @Nailbag
A roof repairer had a look today and found how the water was getting in. Thankfully there's no structural damage, only what you see in the photo.
It looks like the insurance will cover it.
hi @Zog
Thats awesome news and must be a huge relief. 🙏
