I'm currently working my way through re-painting all the doors in my house, and adding new hardware. I'm finally up to the pocket doors, have removed the trim/pelmet panel to get access to the tracks, now I'm reaching out for some further advice on how to remove the doors (5 total).
I do want to remove the doors fully, so I can give them a proper clean and sand, adjust the cutout for new hardware, and then prime and spray them. Leaving them hanging and attempting all that is a no go.
From what I'm seeing, all doors are on a J-style (?) track, but there seem to be 2 types of brackets used. One style has a latch style piece fastened with a nut (this is on 2 doors), and the other only the nut and possibly a washer (on the remaining 3 doors).
There is still about 1-2cm of door in the frame when the door is fully closed, so I can't simply tilt the out and lift of the tracks. I was hoping to be able to lift them out, to avoid finicky adjustments when re-hanging, but it does look like I might need to take that route.
If that's the case - that I need to loosen the nuts - does anyone have advice on the best strategy to remove and then re-hang once I've finished painting? Seems like it would be challenging to get level again etc.
Grateful for any advice, tips and tricks you might be able to share :) Thank you!
