Hi Community!
I've recently began painting the exterior of my house. I've removed the awning (pictured) to paint/restore it and paint the weatherboards around it easier.
I expected it to have been fastened to the frame of the house, but to my surprise there were these long screws that came out, and there was no house frame behind them. Is it safe to assume hollow wall anchors were used?
Not sure if relevant, but the holes in the weatherboards were around 12mm in diameter, much larger than the screw diameter.
What would be a suitable set of fasteners to use when I go to re-mount the awning?
The awning itself is around 20-25kg at most. I will likely be re-attaching it to the same place (so I'll need to make the the 12mm holes aren't an issue for whatever fastener I will be using). In the absolutely worst case I can move the mounting points elsewhere and just fill the old ones (if the 12mm holes are an issue). There are a total of 4 points where it was fastened.
Thanks!
