Hi there,
I'm replairing 2 holes in my garage ceiling. There's no existing support to attach the drywall and wanted to check if 75 x 25mm L/M H3 Treated Pine Sawn CCA is safe to use as support?
I'm more concerned about safety about potentially attracting termites. Also confirming there aren't any termites activity. I know it's treated but thought I'd check just in case.
Checking too if the entire wood (external and internal) are treated? If I cut the wood, would the fresh side also be considered treated or could that be a termite or other insect magnet and would need to apply some protection?
https://www.bunnings.com.au/75-x-25mm-l-m-h3-treated-pine-sawn-cca_p0051358
