Hi, I am DIY and was long time planning to enclose one side of my Outdoor Alfresco Room.
View of Alfresco Area as below.
and plan to cover one side with timber framed wall as per below.
Accordingly, I have made timber frame as per below.
all the four sides (top/bottom/left & right) are with 90x35 H4 treated pine, stood up the frame and fixed to all sides as below.
Now, I have a doubt about closing the external side of the timber frame.
I am thinking of using blueboard and render it. I am doing this as DIY and this is the 1st time about to render, I am also thinking of using fiber cement sheet and paint with textured point to match with existing EPS cladding rendering as shown in the picture.
Kindly advise which one is best suitable to use to cover this external side of the wall ?.
I have also fixed the timber frame 15mm inside to the level of existing rendered wall above so after installing cement sheet or blueboard with render, the new wall can be to the same level of existing rendered wall above to that.
