Hi Bunnings Team,
I’m planning a small shed floor using deck blocks and wanted to confirm a few things before purchasing materials.
The base will be 1.5m between each deck block, with approximately a 300mm overhang on each side, as shown in the Deck Block brochure. Would this span be structurally adequate, or would you recommend adding two additional deck blocks for extra support (as shown in the lower example image in the brochure)?
I’m also planning to use H3 treated timber for the framing. Would 45mm x 90mm be required for this span, or could I use a smaller section such as 45mm x 50mm to keep the floor height lower to the ground?
I’d appreciate your advice on the most suitable setup to ensure the floor is strong and compliant.
