The Estilo adjustable frame has flexibility and the width can adjust from 830 to 900 which is ideal
Have read and reviewed installation instructions which has left me confused, can you please help.
- Page 3 – box content only one wall profile while page 4 assembly diagram shows two wall profiles, in my case I need two.
- Page 5 Installation step 1 also shows two wall profiles
- Page 3 box content – one door frame + one fixed panel, it appears all as one straight assembly – can I assume it has a full frame with the glass door fitted into the frame with the top/ bottom pivots already assembled.
To adjust this frame I assume you open the door and move the sections to achieve the required width.
In all the installation steps the bottom frame does not appear to be secured to the base.
- Page 4 Assembly Diagram – The side of the door with the handle shows two profiles at the top – assume one is to attached to the wall as a wall profile and the second frame fits into it and receive the door when its closed.
- None of the assembly diagrams show the door as a moving part and how the door aligns to the fixed panel. With the pivot point offset we can only assume the door and the fixed panel over lap and the closed door is at a slight angle to stop the two pieces of glass touching each other.
- If you go to the review section, the demonstration by Andy is similar to my cubical. other customers raised issue which have not been clarified
Can you please answer my question or provide more detail instructions/video and help me move forward, keen to purchase this shower screen
