Referring to my attached image.
I would like to add 25mm or 40mm Foilboard in between my top hts in my garage.
I will then use 9mm VJ board as the ceiling.
I have not used Rigid Foil Board before so my questions will be basic.
- Does it matter which direction the foil board runs? i.e. do boards need to rnu in a specific orintation to maintain rigidity?
2. Would the boards be ine if they sat on the top hat ridges or do they need to be fastened?
3. If I was to fasten the foilboard what types of clips/screws should I use?
Thanks
