Hi everyone,
I have a Ryobi RLT254CDSO 2-stroke petrol line trimmer (manufactured 2021). The engine starts and runs fine. However, when I press the throttle lever to cut grass, the trimmer head does not rotate.
Here’s what I’ve checked so far:
- I opened the upper shaft section and confirmed that the top half is rotating when the throttle is pressed.
- The lower shaft is an expandable attachment type, connected with a pin lock.
- I removed the inner drive cable from the lower shaft, and it appears to be broken at the bottom end.
- I attempted to open the bump feed head but couldn’t figure out how to remove it.
My questions:
- Does this sound like a broken lower drive shaft cable?
- If yes, do I just replace the inner flex cable, or do I need to replace the entire lower shaft attachment?
- How do I safely remove the bump feed head on this model to inspect it?
- Are replacement parts (drive cable or lower attachment) available at Bunnings?
I’ll attach photos of the shaft wire and the head for reference.
Any guidance on the next steps would be greatly appreciated.
Thanks in advance!
