Hi All,
I have this Gutter in my patio room which is covered by kind of in sheets and roof tiles. Could you please let me know the options to clean it as DIY. Is the sheet needs to be taken off or any other option available.
Thanks you
Regards
Arun
Hello @Wildhogs10 (Arun)
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your gutter cleaning options.
If you are referring to your polycarbonate roofing and tiled roof. I suggest using 30 Seconds 5L Roof Treatment Concentrate. This is the only product that I am aware of that is safe to use on polycarbonate as it is bleach-free. This is also safe to use on your tiled and galvanized roof. Should you decide to use a pressure washer, please keep in mind that if your polycarbonate is quite old it may have become brittle and using strong water pressure on its surface may break or crack its surface.
One other option is to engage the services of a professional roof cleaner. They will have the equipment and experience to safely clean your roof.
If you are working at height, please make sure to use all necessary safety equipment such as roof harnesses and scaffolding frames. If you are using a ladder, I suggest having a look at this guide - How to use ladders safely by @Adam_W.
