Wondering if the TerraForm 100mmH x 200mmW - 1.60mm Gauge Corten Steel Connectors and also the TerraForm 400mmH - 1.60mm Gauge Corten Steel Stakes would work the with Jack 1800 x 100mm Oxy-Shield Garden Edging?
Thanks! 👍
Hi @Ashland2023,
Since we don’t stock the TerraForm range in-store, we can’t directly verify compatibility with the Jack edging products. Because these companies haven’t tested their products together, we can only go off the specifications and it does look like there’s a good possibility the TerraForm connectors and stakes could work with the Jack 1800 x 100mm Oxy-Shield Garden Edging. However, I’m unable to guarantee that for certain.
Is there a particular reason you’re looking to mix the two brands for this project? Using all components from the same brand is usually the safest way to ensure everything fits and works together smoothly.
Thanks for such a quick response!
We have some existing edging which is the Jack edging, and looking to extend some areas but don't like the look of the exposed joiners/pegs that Jack has.
The Terraform Edging accessories state that they slot together using the rolled edge and then are fixed together with tek screws.
If they didn't perfectly match up, you could always bend that rolled edge slightly using some pliers or a screwdriver to open it up enough, then crimp the edge back together with your pliers.
I'm relatively confident that you could make it work.
