Hi there,
I bought a louvred pergola but have a question on where and how to secure the posts for stability and longevity.
The issue I have is the pergola will be installed over a semi recessed spa area which consists of a concrete slab bordered by a single course of large (600x300x300) limestone blocks cemented together. Unfortunately the spacing between the pergola legs is just wide enough that they will sit off the concrete slab.
So I can either mount the posts to the top of the limestone blocks or try and remove some blocks where the legs will sit, pour concrete footings and mount the posts to the footings once they cure.
Mounting to the top of the blocks with chemset and threaded rod is obviously quicker and easier, plus keeps the steel feet and posts out of an area where water may pool and thus reducing chances of rust. In terms of aesthetics the pergola will be 300mm higher and block less of the view of the parkland and large gumtrees through the back fence. Though one thing I am not sure of is the ability of the blocks to withstand the wind loading when the louvres are closed. My gut tells me this would be fine as the blocks are huge and are cemented together, plus I believe any gusts of wind strong enough to move those blocks would deform the louvres before causing any movement of the structure itself.
Removing blocks and pouring footings to mount to is much harder to do but the more by the book method. I would have to find some way to cut and move the blocks, which google estimates may each weigh 100-130kg. Then I would have to retain the soil that the blocks were retaining. Then pour the footings and then mount the posts to the footings. This would obviously leave an unsightly gap in the blocks, and be an area where water may pool. Plus would put the pergola roof at a lower height.
I have already checked with my local council, no permits required to install this pergola. So my question to the brains trust is this, do I trust my gut and go with simpler installation method? Or do I spend the considerable effort into the more complex method?
Thanks for any advice
