Hello, looking for advice on how to install a flyscreen here and which product to buy from bunnings.
Measured the entire windows Length: 140cm and Width: 96cm (where i want a flyscreen 45cm)
Thank you
Hi @RenoFun,
A framed flyscreen will usually slot into a channel in the window frame. It's tough to see in your photos if there is a dedicated channel on either the inside or outside of the door or window, but I suspect you could use this channel here.
So, you would need to know the width of this channel so that you can purchase flyscreen frame that will fit snugly in a channel around the opening.
This Pillar 25mm x 2.5m Mill Flyscreen Frame is 11mm wide, which is fairly standard. Depending on your circumstances, it may be an option.
From there, you can follow this handy step-by-step guide on How to build a flyscreen frame to create a flyscreen frame.
Have a read and watch the video, then let me know if there is anything that you don't think applies to your scenario so I can assist further.
