Hello Team,
I need help to install the Matrix Fence extension (2410 x 600mm) on my color bond fence outside.
- Got the below Matrix Fence extension https://www.bunnings.com.au/matrix-2400-x-600mm-charcoal-coolabah-fence-extension_p0029255
2. Got the recommended Legs (Code 33652 ) from Bunnings for Steel fence - which contains a L bend at the middle and 3 Pre dilled holes.
3. The instructions to install on the steel fence is very confusing (attached)
As per instructions the predrilled holes is to attach the Fence Extension to the leg. But the Fence extension is 600mm wide and the leg part with predrilled holes is only 580mm and hence it is never going to aling with the top and bottom channels of the fence extension.
Question 1 : So should i turn the leg and use the 600mm length part and drill holes to attach it to the Fence Extension ?
Question 2 : Should i be screwing through the leg into the fence extension, or through the fence extension into the leg?
Clarification - is Does the Fence extension lean toward my side or the neighbours side ? what the intended design ?
Can anyone please assist with this - the videos does not show for Color Bond fence and i have googled the earlier Bunnings blogs and it does not help to clarify my queries.
This is very confusion to install - been struck on this and not able to complete the work
Can anyone share a picture if they installed one on color bond fence.
