There is a gap in the joint/seam of my stone kitchen bench which allows water/liquid to pass through and drip into the cupboard underneath. The material that was used previously to fill the gap has largely deteriorated and needs to be removed and replaced (refer below image).
Do you have any suggestions for how to remove the remnants of the old filler as well as what material/method to use to reseal the gap to look as neat as possible (for an amateur DIYer).
What I have determined from my limited internet research is that epoxy is generally preferred to silicone for this type of application. Is that correct?
Thanks,
Mitch
