True Blue Pool 3 Way Valve 40MM I/N: 0510726
is there any rubber o ring if you unsrew the black plastic ring and remove handle ? thanks
Hello @angao
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your pool valve.
I suggest going to your local store and speaking to a team member at the special orders desk. They can find out for you if the O ring is available as a spare part. You can also fill the form on the Spare Parts page or call them direct on 1800 772 737.
Hi @angao,
Yes, three-way valves typically have a seal, and often an O-ring, to seal the thread for the handle section. Without a seal there, water would migrate at the join. Is there a problem with your unit leaking, or is it missing a seal?
Thank you both, to Mitchell, yes, water leaking around handle ,too messy to cut pipe and replace the whole valve, thinking just replace damaged o ring.
