This is a very common question, and I am yet to find a workable solution. How do you extend the shower breech seat outwards by less than 28mm?
I have a set of quite expensive designer taps and the whole matching bathroom set for a refit / renovation. The provided spindles for the taps are adjustable from 80mm to 85mm in length and they have a proprietary design spindle end connector that fits into the tap handle and is secured by way of a locking grub screw.
I need to extend the breech seat and using Ceramic Disk Spindle (or breech seat) extenders appears to be the only way to do this. I cannot use the external extenders that just provide additional thread length outside the tap as this is not the problem. When I install the Kinetic 28mm Ceramic Disk Spindle Extenders they protrude out from the tiled wall surface by about 4 - 5 mm, preventing the Tap hardware, ie; backing plate and nut, from sitting back against the wall. The hexagonal nut section on the extenders is larger diameter than the hole in the backing plate and nut hardware of the taps.
The obvious fix is to buy a set of longer ceramic disk 1/4 turn spindles or reuse the ones that are already there and working, but the manufacturer doesn't sell longer spindles to suite these taps and the splined of double flat threaded styles do not have the facility to attach the correct handle connector.
I have considered the possibility of machining the 28mm extenders down to shorten them, but this would remove the entire internal threaded section, meaning you can't screw the spindles in. I haven't checked to see if this would work even if the threaded section went deeper.
So, is there a way of extending the breech seat outwards by a distance of less than 28mm? All available brands are the same 28mm.
Note: it is not possible to access the internals of the wall to re-position the breach.
