Purchased the Kaboodle Oven carcass and need to know if the following appliances can be installed above each other with the setup mentioned below, having issues figuring this out (Have not purchased the appliances yet). Cannot figure out the clearance required between the wall on the left and cabinet on the right either!
The oven Carcass is against a wall (left) and against a tall Kaboodle cupboard (right). So sandwiched between both.
The appliances: Samsung 60cm Built-In Oven and Samsung 60cm induction. Dimensions for both below.
Also I can't figure out if they need a thermal barrier? between the cooktop and oven.
Electrician will be doing the installation/wiring but it is up to me to purchase the appliances so need to ensure they will fit! ANY help appreciated!
