Hi community i am here to get help that howcan i connect washing machine pipe with sink pipe? Thanks in advance.
Hi @furqanchoudhary,
Assuming the hose fits over the barbed connector relatively snug, then the only thing you would need to do is use a hose clamp in a suitable size to lock the end of the hose on to the barb.
If your current hose is too large, can you let me know what the outside diameter of your hose is and the outside diameter of the barb is?
If they are relatively standard, then you could simply attach a Nylex 34mm Reducing Joiner to the end of your hose and then clamp it on to the barb like above.
You might like to check out step 5 in How to connect a dishwasher where my colleague Mitchell demonstrates how to attach an outlet hose to a barb.
Let me know how you go.
