Attached are two photos of a shower head that I can adjust the height.
My question is what do I need do to make the shower head to sit up properly rather than droop on the photo ?
Regards
Gary (Armadale Melbourne)
Hi @GaryArmadale,
The rigid cylindrical piece that forms the connection between the shower head and the hose -
needs to sit inside the shower rail slider -
In theory, it should just fit, but I have heard of some shower rail sliders where the diameter of the opening is smaller on one side than the other, in which case, you may need to rotate it 180 degrees so the side that is currently facing the wall, is facing out. If this is the case, there may be a screw at the end of the slider that needs to be loosened or removed to allow this.
Give this a try and let me know how you go. I am happy to assist further if required.
